I have a 2004 Jetta, BEW, manual, 135K miles. I am inspecting my camshaft. I see the posted pictures of camshafts, but I can not judge if the camshaft is good or not on my car.
Thanks to all who make this an informative site.
I thought all the edges felt the same. The bevels all looked similar. I don't have enough exprience to know the difference between a good one and bad one.
I tried taking a picture, but the resolution was not very good.
The camshaft bolt is on a nub which means I couldn't use my universal counterhold tool and obviously you don't want to use the timing belt to counterhold against a 79 ft-lb bolt. The other tool is a puller since it's pressed on. Since you're removing the camshaft it's possible to get it off and knock off the pulley while it's off the car, but this is easier and makes removal easier too.
Also, post moved out of intros and title edited to reflect the more technical questions here.
No but if you remove one of the 13mm camshaft sprocket bolts, the other 2 will hold it fine and you can measure that. Just make sure to put it back to 18 ft lbs before you run the engine.
