1 - 7 of 7 Posts
Hi I’m obviously new to this forum so here my introduction lol
My name is chris but call me dycie, 31yo drive buses/coaches.
My car is a 2006 skoda Octavia vrs pfl with a 2.0tdi PD170 BMN, current mods are DPF, EGR, inlet flap deletes, alloy wheels & coilovers.
I have an issue that absolutely no one can figure out :( when accelerating at about 2k revs it’s stutters, hesitates and surges there is not fault codes what so ever, and nothing obviously wrong. I’m at a complete loss with it please someone help me :(
welcometomyturbodies
We do have a Seat and Skoda sub forum.
Manufacturer: Skoda, Date(s) Used: 04/2006-05/2008, Model: Octavia, Engine Code: BMN, 125Kw, 170PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD), EU4+DPF, 16v Timing belt
  • Like
Reactions: Dycierfc1988
Thanks pal so anyway do you have any idea about my problem? Cheers
Scanned with what?
Is the car mapped? I'm sure it needs mapping for the dpf delete etc. I think the intake flap thing also varies the air flow on the 2L But not a 100% sure.
I know it's fairly common for the 2L to have a little flutter around 2000 rpm but it might be exaggerated on yours due to the mods.
Just a thought
Discussion Starter · #6 ·
No
Scanned with what?
codes stored at all via VCDS, I’m thinking it obviously mechanical rather than sensors or electrical components
Discussion Starter · #7 ·
Just a thought
It only has the DPF & EGR Deleted from the ecu this has been done by 2 specialist garages in my area to which both can’t tell what the problem might be but can tell me the software is fine
1 - 7 of 7 Posts
