I have a strange thing happening, if the outdoor temp is around 0 deg C, the car won't start on first try, I have to keep the key on while it cranks enough cylinders to fire and start. after it has started it runs fine. At -5 or so, I have to try numerous times to get it to go. At -10, there was no signal to crank the starter. My battery is two years old and I replaced the glow plugs with no change. Any clues as to what is going on? Any help would be great, thanks.
Welcome back you've already made an intro in 2011.
That isn't an easy question to answer on a forum as we don't know the history of what has been done/tried.
Get the batter and starting system checked out.
Discussion Starter #4
I haven't used conditioner as I have never had issues with gelling at these temps. I only experienced that once when it was -30c.
Lots of diesel now days has a percentage of Bio in it. It will gel at a higher temp. Check with the station you get your diesel from? If it has Bio, get it somewhere else or use lots of additive. Just a thought...
