Hey Everybody,
This might be a fun one to figure out.
Last week I took a road trip with the family. Destination was about 280 miles. About 2/3 the way up, I started to notice a greater than normal turbo lag. I could be cruising at 65-75 mph, let off the throttle, apply throttle, and there would be a delay, then after a second or so with no increase in throttle, it would finally accelerate. Never noticed any visible smoke. After exiting the freeway, starting out in first gear, I noticed a definite hesitation from idle to around 1800 rpm. After 1800 or so, it runs fine. It also had a noise associated with it that I could hear happen twice before acceleration felt normal. It sounded like the Intake Flap opening and closing, but louder (obviously because I could hear it over the engine). The same type of hesitation happens in every gear. I did not have a VCDS with me, but I did have a Blue-Point Scan Tool, which I connected, and no codes showed up. Took it to a Stealership, and the tech and I took it for a test drive. He could feel the hesitation in it, so they took the car in the shop. An hour later he came and told me that they could not find anything wrong with it, except that the EGR Cooler is beginning to leak. Fortunately, they didn't charge me anything for looking at it, so that was cool.
Now, I did get a VCDS, and now I'm just trying to figure out what the problem is. However I am totally new to using it, so I need some help figuring out what to look for. I used to be able to accelerate smoothly from idle to 2000 RPM, and everything felt good. Now it just kinda lurches until 1800 or so, then it's all good from there.
I've looked through the MAF Sensor troubleshooting, and just took a peek at it, found that at idle it was averaging around 400. The VCDS said that at idle it should be in between 150-300 I think. So possibly a MAF Sensor problem?
Just today I did adjust the cam timing, VCDS showed that it was running at -2.0, so I adjusted it to +1.0. Also, I did perform a camshaft inspection, and fortunately, everything looks good there.
Almost forgot, this issue is more noticeable when the Air Conditioning is being used.
Suggestions?
Suggestions?
