I finally got a day off from work and decided to do the timing belt change on my Beetle. I'm stuck on how to get the motor mount support(the one attached to the engine)out of the way where I can get the tensioner and timing belt off. The directions stated to work around it but the mount has an extension on the back side(long bolt goes through) that will not allow me to manuver it in a position where I can remove the tensioner or the belt. The belt is off the crank and cam gears but there is not enough clearance to get it past the extension on the motor mount. Same deal with the tensioner. Do I need to remove the stud the tensioner mounts on? I've tried raising and lowering the engine to the extremes in both directions and still no success. Appreciate any info on how to proceed. Thanks a lot. Don
