1 - 7 of 7 Posts
Hi gents,
I'm having an issue with my 2014 TDi VW Passat.
I can't keep my long beams up , reverse cam doesn't activate and Windshield Washer Pump don't activate.
I'm under impression this would be a relay issue as all 3 don't work . VCDS only gives me an error for Windshield Washer Pump?
I would appreciate if some one can provide relay and fuse box diagram for this model. If I'm going down wrong path, please I'm open to ideas.
Many thanks in advance.
Tuesday,26,November,2019,17:41:58:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ3CZFE040562 License Plate: PASSAT1
Mileage: 64920km-40339mi Repair Order: P1
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
56 61 62 6C 6D 72 77
VIN: WVWZZZ3CZFE040562 Mileage: 64920km-40339miles
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
Address 01: Engine (J623-CFGC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RG HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9978
Revision: 41H28--- Serial number: 00000000000000
Coding: 001D0012042501080000
Shop #: WSC 41440 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018RG 003007
ROD: EV_ECM20TDI01103L906018RE.rod
VCID: 000FB3209BA0284FA7-8054
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 N HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4009
Revision: 05652104 Serial number: 00001407051096
Coding: 0000020
Shop #: WSC 05311 000 00001
VCID: 204FD3A0F360C84F87-8074
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BM HW: 3AA 614 109 BM
Component: J104 C2 450M VD27 0040
Revision: --H07--- Serial number: 00000008328185
Coding: 0008124
VCID: 79F9DEC4307A7987E0-802C
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 BQ HW: 3AA 907 044 BQ
Component: Climatronic H05 0607
Revision: 00001K02
Coding: 061401A003
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 P HW: 3AA 937 087 P
Component: BCM PQ47 H 422 0475
Revision: BB422001
Coding: 0008000000000000009800805400816403510088426D8560648046200041
Shop #: WSC 05311 123 00001
VCID: 479D683CF60EDF7726-8012
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 13061 26 0612
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 140714 05 54 0403
Coding: 0230ED
2 Faults Found:
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 64922 km
Time Indication: 0
Date: 2019.11.26
Time: 17:06:27
Freeze Frame:
Term 15 On
Voltage: 11.70 V
OFF
ON
ON
OFF
OFF
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 64922 km
Time Indication: 0
Date: 2019.11.26
Time: 17:06:27
Freeze Frame:
Term 15 On
Voltage: 11.70 V
OFF
ON
ON
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28201418902150
Coding: 308102
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3F8D70DCA6DE97B79E-806A
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AE HW: 5N0 959 655 AE
Component: J234__105 VW10 HI 2418
Revision: 29020000 Serial number: 003N5PCZ79UK
Coding: 0012341
VCID: 000FB32053A0284FA7-8054
Subsystem 1 - Serial number: 6332MTS646111854
Subsystem 2 - Serial number: 6342MTS602591864
Subsystem 3 - Serial number: 6351HTS6VVID0DKR
Subsystem 4 - Serial number: 6361HTS6TA0S2DKJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 CN HW: 5K0 953 569 AS
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140714300205
Coding: 198A250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 77FDD8FCCE6E6FF796-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 871 A HW: 3AA 920 871 A
Component: KOMBI H03 0905
Coding: 161F01
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 316926E4608A71C718-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 050714F1000398
Coding: 462007
VCID: 000FB32093A0284FA7-8054
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 E HW: 3AA 959 433 E
Component: IMMO 048 0407
Revision: 00048000 Serial number: VWZCZ000000000
VCID: 3B7504CC7AC68B97B2-806E
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0008861007
Coding: 0206B7
Shop #: WSC 05311 115 00001
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 356112F494E25DE744-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 005 0503
Serial number: 00000004076874
Coding: 010690
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 196 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39791EC470FAB987A0-806C
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ47 ELV 048 0700
Coding: 02900A80D2830E76340494157C085F0B005800
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000008
VCID: 6FEDE09CBE3E27374E-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0008865703
Coding: 0206B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 366315F889E456FF4D-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 005 0503
Serial number: 00000004079843
Coding: 010690
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000180154
Coding: 0022167
VCID: 387F1BC04BF0A08F5F-806C
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 T HW: 1T0 035 680 T
Component: RNS-MID H23 6270
Revision: AB001001 Serial number: VWZ6Z7P9191071
Coding: 04000402040000A00011
Shop #: WSC 28620 002 1048576
VCID: 3F8D70DCAEDE97B79E-806A
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V6 7920
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1653
Coding: 330F1859
VCID: 71E9E6E4A80A31C758-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 41184B11181491489614
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H15000 Serial number: 525PA8-JC10129
Coding: 0020007
Shop #: WSC 55005 003 1048576
VCID: 68DF8B805BD0F00F0F-803C
Address 6D: Trunk Elect. Labels: None
Part No SW: 3AF 827 383 A HW: 3AF 827 383 A
Component: J605 HECKDECKEL 0860
Revision: 00H52001
Shop #: WSC 05314 000 00001
VCID: 3A7B01C875FCB29FA9-806E
Subsystem 1 - Part No: 3AF 827 384 A
Component: J756 HECKDECKEL 0860
Subsystem 2 - Serial number: 1400H52001001B0136ÿ
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 HW: 5N0 035 729
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007666424468
Coding: 0A01000080010101
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 6DD1FA94BC32D5277C-8038
End-------------------------(Elapsed Time: 05:31)--------------------------
Fuse & Relay PDF Files
Your after diagrams not layout?
Find someone with ElsaWin.
VAG Error Code: 00897
Fault Location:
Windscreen Washer Pump (V5) - Open Circuit/Electrical Fault in Circuit/Implausible Signal
Possible Cause:
Operating problems.
Wiring/Connector(s).
Loose contact.
Corrosion at plug connections.
Windscreen Washer Pump (V5) defective.
Possible Solutions:
Test wiring.
Check/Replace Windscreen Washer Pump (V5).
Hi Keith , and Thanks for support once again. I’ve tested Washer pump and it works on its own of the battery . I’m suspecting a relay as my long beams Wong stay on or reverse cam don’t switch on ...
What’s the best place to get rely box diagram . My ElsaWin is too old for this model.
Cheers
Al
My ElsaWin is the old one but it shows VW 03/2016 that's were I get my fuse & relay layouts from.
What is the ElsaWin version number in About mine is 4:10? I hate the newer versions 5.1 Plus as it installs loads of crap that's always running.
Audi 02/2016
Seat 01/2015
Skoda 03/2012
VW 01/2017
Discussion Starter #7
Mine is version 4 up to 2012 models.
I might have to find the update. I need to get this sorted , are the other options where to find these?
1 - 7 of 7 Posts
