Hi, me again. Now I have my TB in place, tensioner is tight, new pump and roller are all in. But now I am fighting with my lower engine mount. Can't get that thing in place at all. AC line is in the way, then it looks like the plastic engine side TB cover is interfering also. Then just noticed that the plastic pipe behind the engine is also giving me some problems. Do you guys have any tricks with this mount? I tried lowering and raising engine but without any luck.
Thank you for any advices! - Al.
Discussion Starter · #2 ·
I got it finally. I had to remove the 10mm bolt that holds the plastic pipe leading from the air filter box, and disconnect the hose in order to push the mount left (towards the firewall).
