Sorry forgot all the important info, I keep forgetting that not everybody on the internet is a mind reading Ninja
2002 Jetta TDI, manual trans, power windows/locks, heated seats, IMOBO delete, think that is about it.
It has an aftermarketish radio (BECKER out of a Korean market Tiboron)...I worked for Harman International for 10yrs as a tech/installer in their oem group. The radio k line is not tied to anything.
VCDS Version: Release 10.6.1
Data version: 20100831
Monday, 11, October, 2010, 18:27:07:58422
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75 76
VIN: 3VWSP69M32M000000 Mileage: 366950km/228012miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G440SG 4102
Coding: 00002
Shop #: WSC 00066
VCID: 57B37AEB9F7F
3 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 35-10 - - - Intermittent
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 35-10 - - - Intermittent
16512 - Coolant Thermostat Valve (N214): Temperature below Control Range
P0128 - 35-10 - - - Intermittent
Readiness: 1 3 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 03313 551 00000
VCID: 3167E473D15B
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A75C35F0C2D
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 00000
VCID: 3167E473D15B
3VWSP69M32M007910 VWZ7Z0A3842594
2 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01330 - Central Control Module for Central Convenience (J393)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0E1A1779AD1
1 Fault Found:
End ---------------------------------------------------------------------
