So just picked up a ‘15 TDI and like normal I use a battery tender when my vehicles are not driven for more than 5 days. So I was putting on the battery harness the tender hooks to. While doing so the positive cable slid off battery. Ok no biggie right...so I get in the car to back it out of garage and all sorts of warning lights.
So it didn’t like the battery was disconnected for 10 seconds I guess. I don’t remember my ‘13 Passat flipping out...so it would cause this when replacing the battery?!?!
I tried to reset the TPMS in the glove box; doesn’t do anything. I’m thinking that may be causing the other issues because ESC and traction control use info from there?
I did a scan with VGCS. I clear code for TPMS and it comes back. Wonder if I need to drive it a bit? Or should I disconnect battery again and let it sit?
Go figure my wife was gonna take her new car with the mother in law visiting to the Vegas strip in it; and I dork it up! One of those days I guess!
Discussion Starter #2
Disregard last. After 20 min of finding the right word combo in google; I found all I needed to do was drive the car 50’. Sure enough. Drove around the block and 100’ later all the lights extinguished.
Crisis averted!
