2005 Jetta TDI, 2004 Passat TDI
Hey all, my daughters 2005 Jetta TDI has some sort of clutch issue that I want to confirm before I take any next steps. The problem started all of a sudden... when you apply torque to the engine in any gear I get a Grinding type of noise and RPM's go way up but no positive motion from the car. The same problem occurs in reverse. The clutch pedal engages and disengages fine. The flywheel has made a rattling noise for years when the clutch was not pressed; probably the duel flywheel. This may be an obvious clutch symptom but its different from other clutches I've had on cars/trucks and I wanted to confirm. Thanks all!!
Release Notes
Dual Mass Flywheel (DMF) problem.
