No Low beams- but did have daytime driving lights & High Beams-
I checked/ tried everything listed in this thread including other things I'd read, like spraying some contact cleaner in the turnsignal switch and exercising it but no luck.
I went to a junkyard and got another headlight switch (in dash) and another turnsignal & Hi/Low multifunction switch.(behind steering wheel) Because the dash switch was SUPER EASY to change I tried it first and IT WORKED!
(All lights now work properly)
Wondering if it was really just a loose/ bad connection, I swapped my old Headlight switch back into the car and again had No low beams. Re-installed junkyard switch and all lights work again.
In my case the dash mounted headlight switch was bad, but others report the Hi/Low multifunction switch was bad.
Great Link showing Cruise/Turn signal/Headlight dimmer switch replacement:
http://forums.tdiclub.com/showthread.php?t=151557
Video showing how to remove the dash mounted headlight switch:
http://www.youtube.com/watch?v=5v-RKI5X5Zw
