Post moved to the mk4 forum.
No, 100%.
If there is no clearance then you just have to remove the fenders. Because you also have to drain the coolant, it would make it easier to remove the bumper and radiator support. Without disconnecting the AC lines, release the AC condensor from the radiator support and swing it to the side. Then remove the radiator support. Then remove the fenders. There will be plenty of room to remove the head.
Removing the radiator support may have to be done if they want to pull the engine anyways so the only additional step is fender removal.
If they don't want to it's because clearance is kind of tight in the back. I don't think they should charge you more to remove the fenders vs. pull the engine because removing all the wiring, etc. for the engine is a lot of work.
Make sure they use a new 100k mile timing belt kit, new head bolts, new motor mount bolts (they are single use only).
No, 100%.
