As the title suggests I just took a look at the horror show that is the cam wear on my BRM. I can't get the damn gasket to sit right and it keeps falling out of place. I THINK its in place now. I used some permatex sealant at the required places and tightened all bolts in order with a torque wrench. However The gasket is mushing out in places. A little bit.. not like bad mushing.. Mushing is not the right word. Its a bit visible around the bots.
I took the car for a very very very hard test drive and pulled in my drive way and poped the hood with the engine still running. I had a small plume of smoke coming out from beneath the right "HUMP".. next to the pump side. UGH. There has got to be a trick to getting that gasket right. How did they do it in the factory when they built the darn thing? I would suck working at the VW factory.
Any tricks to getting that gasket straight and true? I ended up tacking it to the cover with some of that sealant crap. I even lubricated it a little with oil.
As for the smoke: I'll put the torque wrench to the nearest bolt.. just to make sure I got it all the way.
Oh.. and the cams are a horror show. More on that later. With Pics. At least there was no sludge and looked really clean and healthy.
