I'll take a look but don't recall seeing any in the past. One thing I forgot to mention is that when the car is running I do hear a sucking noise from the engine on the passenger side up near the firewall. I haven't been able to pinpoint where it's coming from. Maybe I have a vacuum leak?? I mentioned this to the dealer but they didn't say anything about it.
Replace your fuel filter and don't forget the two small O-rings under the clip. What's happening is you are getting "leak back" of fuel in the lines to the fuel tank. As the car ages, the check valve in the lift pump in the fuel tank weakens, or it gets a bit of dirt in the seals allowing fuel to siphon back into the tank when you have an air leak upstream. That air leak is usually the two dried out O-rings on the fuel filter. What this causes is hard starting (lift pump has to "re-fill" the lines all the way back up to the injector pump), a little white smoke, and sometimes rough operation. You can check for this easily. Next time you are driving the car and everything seems normal, shut off the car and immediately pinch off the fuel line at the filter between the filter and fuel tank. Wait an hour or so (or the "normal" interval you are experiencing between shutdown and noticing the hard starting issue), un-pinch the lines, and see if you have a normal start. If normal, you've got an air leak between the pinch-point and injector pump.
Also check for air leaks in your fuel lines at other locations (the "sucking" sound maybe?). If you have an air leak between the tank and where you pinched off the lines, you'll still get leak-back.
I thought I had a glow-plug problem with the hard starting I was experiencing, but it turned out to be the fuel filter O-rings. A fuel filter is cheap compared to a turbo and should be changed periodically anyway. Hope this helps.
-David
