I've read the FAQ about hard shifting into first but I'm having problems shifting into 1st, 2nd, 3rd, and reverse gear with my Mk3 Jetta. It seems like you just can't push the clutch pedal down far enough to fully disengage the clutch. And, as you might expect, the clutch engages very early, with the pedal only about an inch, or less, off the floor. Shouldn't it engage much higher? Is there some way to adjust the height at which the clutch pedal engages/disengages the clutch? From what I've read, no. Or, is this just a differently described example of the FAQ shifter cable adjustment demo? The clutch has shown no signs of slippage.
