I followed the following instructions to silence the door chime:
Please help. Thanks!
The article mentions gallons, temperature, time and units but nothing about speed. I have read through this article and a couple others and can't find where this is adjusted in the MFI. Is this controlled by a VAG-COM setting I am not aware of? I really like the changes the "GB" country setting has ushered in but I may have to revert back to "US" setting if I can't get this changed as it's very distracting and useless for me. The other alternative I suppose is to suppress it (by unchecking), but I like to keep the big MPH setting up for when I am not in Cruise Control.This page shows how to disable the door open chime on mkvi VW model years 2010, 2011, and newer.
You can use VCDS to disable the door open chime by changing the software code from America to Great Britain. Don't do this modification if it's illegal where you live or operate the car. It can be changed back at any time by changing the software code back to America and you should do so before reselling the car.
This also changes the multifunction display/indicator MFDMFI from US gallons to UK gallons (UK gallons are bigger. This is one reason why European mpg ratings are so much higher), Fahrenheit to Celsius, and the 2 hour clock to a 24 hour clock (military time). If you have a highline display you can change all of these back to their original settings. See 1000q: MFD settings for more details.
http://www.myturbodiesel.com/1000q/a6/door-chime-disable-golf-jetta.htm
