Hi
Im replacing the timing belt on my golf with ALH engine and have put the new belt on without loosening the 3 bolts on the injection pump. The engine is turning fine by hand and everything including the slots in the pump lines up when its at TDC, but Im a bit worried that the tension on the belt will be uneven because I didnt loosen the bolts. Does anybody know if this could damage the belt or anything else? Any thoughts would be appreciated.
Thanks
Thanks
