I don't know if a bad BCM is your issue but probably not a bad guess. If you purchase a new or used BCM then you can certainly reprogram it with a Vag-com. That could also be a good investment to try and do some diagnosis on the issue as well.
Thanks a lot for the help, I got a BCM and now am looking to get a vag-com to program itI don't know if a bad BCM is your issue but probably not a bad guess. If you purchase a new or used BCM then you can certainly reprogram it with a Vag-com. That could also be a good investment to try and do some diagnosis on the issue as well.
Thanks a lot for the reply, I found a bc-module but Im not sure about it will match my car, the one I got is 1K0 937 084 G compared to yours: 5K0 937 084 G. I would compare it to the current one I have nut my dad told me the bcm was probably swapped before so I dont trust the current one. My car is a tsi with sunroof (not leather) with 2.5 engine.if you have sun roof check your BCM that's the only part controls most electronics, I had similar issues with my reverse light, get it out opened check for damage, the only way you can avoid reprograming if you can find one with the same serial number, or if you go to junkyard find one from a car with the same features, or ebay has tons of it for 150 dollars.
View attachment 10020 View attachment 10021
