Hi! My 1.9 TDI150 PD has a problem that I found after a DYNO test: I have max torque at 2850rpm instead of 1900 and the torque is 289Nm instead of 320Nm and max power 99kw instead of 110kw. The biggest problem that I want to resolve is the max torque delay. I think that the problems are turbo related so i did a scan with vag com. there is no fault code and while logging intake boost pressure there is no major difference between specified and actual value... so any suggestion? a second question is why i'm getting actual pressure without mbar in vag com? because of that i can't see them apropiate in graph. it's pissing me off. I attached dyno log an vag com group 11 log
