1 - 6 of 6 Posts
How much will it cost to replace the glow plugs in my 2010 TDI jetta sportwagon?
Who told you there was a problem with the glow plugs?
Discussion Starter #5
Glow plug light came on,It was the throttle actuator that had to be replaced .Im covered under the extended warranty from Volkswagen,glad to keep my TDI I now have two hundred twelve thousand im going for threehundred,will my DSG transmission make it??
DSG have low reported failure rate, just keep up with your filter and fluid changes.
Glad you found a simple solution that didn't break the bank, and thanks for following up on the initial post to close the loop.
1 - 6 of 6 Posts
