1 - 8 of 8 Posts
VW beetle 2001 tdi
Fans don't work neither with A/C button pressed or w/o.
30amp fuses on top of battery are all good and the fuse holders are not melted.
Large fan works slowly when I remove fuse #16.
Can someone help please
Have you been through all the fuses in the car? There might also be a relay but I'm not sure. It might be worth a search as well as going through the faq pages if you haven't already, if I come accross anything useful I'll post back.:)
welcometomyturbodies
There are a couple of AC fuses.
Fascia 1 fuse box.
F16 - 10A - AC compressor clutch, engine coolant pump motor, engine coolant blower control module.
F25 - 25A - AC/heater blower motor, air conditioning (AC)
The 30A fuses F3 & F6 in the engine bay are for the engine coolant blowers motors 1 & 2.
Discussion Starter · #6 ·
Keith,
As I mentioned on my post I have checked all the fuses and no one is burned.
The only thing I didn't checked is the relays because I don't even know where they are located.
Thank you anyway.
1 - 8 of 8 Posts
