Remove the large plastic panel under the steering column. You will see the relay panel. There's a relay labeled 109. The normal failure mode is stalling when normal driving, unable to start for 5-15 minutes, then it starts normally. This is due to a bad solder which fails. The newer design relay 109 is grey, the old design is black.
