have you trye type flex seal check inside around the connector for any damage use a smooth sand paper around make sure is clean when you put it back, if there is damage on the tread there is a tool to fixed otherwise nothing else will work.
Flex seal? I tried sanding and looking for damage or dirt and found nothing obvious threads are fine as wellhave you trye type flex seal check inside around the connector for any damage use a smooth sand paper around make sure is clean when you put it back, if there is damage on the tread there is a tool to fixed otherwise nothing else will work.
I had that issue before connect the line first on the HPFP then on the on the riel it needs to be well alignedFlex seal? I tried sanding and looking for damage or dirt and found nothing obvious threads are fine as well
I ended up buying another hard line ($50 compare to the $700 for the pump) it is not leaking right now we will see how long it lasts this time 🥲
where are you located I have one that I get from a junk yard.I ended up buying another hard line ($50 compare to the $700 for the pump) it is not leaking right now we will see how long it lasts this time 🥲
