1 - 11 of 11 Posts
Why would this happen? I wasnt having any vibrations or other problems with clutch. Have the trans off for rebuild and see I need clutch friction plate.
But I found the flywheel holes not plumb with the 12M triple square bolts. Cant get the TS tool into the bolt heads.
Any ideas?
It's a dual mass flywheel and they tend to wear. This allowed movement and it got used to being moved in the direction of the greatest force. There's a lot of posts with similar pictures and people asking how to get them off.
You should be able to stick the point of a spud wrench into the head of the bolt and give yourself enough space to get a wrench in the head.
Sent from my moto g(7) power using Tapatalk
Discussion Starter #7
Thanks for the links! Thinking I'll sound incredibly naive I'll ask anyway.
Any harm in just leaving it and replacing the friction and pressure plate? Or is it in a state of immediate doom?
Discussion Starter #8
Thanks for the pro tips! I got them out by pounding the tool in with a hand sledge, then air hammering the bolts loose in roatation until they were all out. They would not clear the holes. I could not pry the thing into alignment. Plasma cutter was catching my eye over in the corner of the shop...
Thinking I will switch to smf. With 330000 miles, will the cheapest ones outlast the rest of the car?
If the pressure plate and friction pass are in good enough condition there should be no harm, other than having to take it apart again sooner.
A single mass will Outlast the car. Just need to resurface the plate with a new friction pad install. My buddies use a rotary tool with an abrasive pad on low speed. Just enough to take the glazing off.
Discussion Starter #10
Thanks so much, eddielee. My current friction plate is toast. So buying clutch kit everything. Going with Southeast Clutch. No real reason for them other than number 4 on a list of reputable clutch manufacturers and price. Looks like no science behind the list, though. :rolleyes:
I have a South bend came with a Sachs friction pad.
I look around on the tdi specific sites and base judgement on them.
Random internet reviews seen to deal more with gassers and I drive a diesel with a lot more torque...
1 - 11 of 11 Posts
