hi guys, im a newbie to forums so sorry if I'm lacking any etiquette. Basically I nipped to the shops earlier, car fired up fine, came back to my car and it wouldn't start. It was turning but just wouldn't fire.. I saw a flashing coil on my dash, but since I'm working from home I had to run back to get on a conference call. Later I returned and my car started and drove fine. Once I got home I turned it off and fired it up again a few times and it was fine. Left it 5 minutes and it wouldnt fire again. Guy next door hooked it up and it spat code p060600 ecm/pcm processor. Any ideas on where to even start? All I know is it sounds expensive...
:cautious:
What was that error code scanned with P060600 as there are to many 00's at the end, a generic scanner?
