http://www.myturbodiesel.com/1000q_how_to/a5/fisconbluetooth.htm
Thanks to fixmy59bug for the procedure and pictures. I added some notes in the introduction, a youtube demo (german text), and a direct link to the part.
This mod will only work on red screen MFD displays. It will not work on white MFD. It displays extra gauges on the MFD like actual water temp, boost, and actual water (and engine coolant) temp. On the water temperature gauge on the instrument cluster, it goes to point straight up and stays there until the car is cold or already overheating. The reason modern gauges in general are dampened is because it's easier to manipulate electronic signals vs. an analog gauge. It also prevents people from freaking out when the gauges show actual readings. For example, it would be normal for the coolant temperature gauge to read higher in the summer than in the winter.
