I just recently bought a 2006 VW 1.9 TDI beetle to drive to work and around town, I am having a issue that I can't figure out. First thing I did was a full service oil, oil filter, fuel filter, pumped the fuel because it was sitting for 2 years, it will sit and idle all day but when you drive it randomly wants to cut off and most of the time it does touch the gas and it will shut off. It does have two codes P0263 and P0272 contribution/balance problem with #1 and #4 cylinder. Something I noticed there is a connector unplugged when you plug it in it will NOTstart looks to be the cam position sensor unplugged possibly cam timing off?
The car will get up and run on the highway fine..... Just when it comes to taking off/stopping it wants to stall and most of them time it does, also if you hold it around 1k RPMS it sputters a little.
Any help/info is appreciated.
Thing I have done since I bought the car or have been replaced before I bought it.
New timing belt/ head reworked timing belt broke. "previous owner"
New ac compressor
Oil filter
Oil
Fuel filter
Coolant flush
Thermostat Replaced
Serpentine belt Replaced
Discussion Starter #2
Did confirm it was the cam shaft position sensor unplugged, will not start when plugged in and I ordered a new crankshaft position sensor.. maybe that will fix the stalling 🤷‍♂️
Welcome to the forum.
An intro is what its for not posting problems, make a new thread about your problems as I don't want to bog down this intro with them?
Release Notes
