If you have a sunroof, you should occasionally clean out the drains. If you don't water can get blocked in the drain lines and leak into the interior.
http://www.myturbodiesel.com/1000q_how_to/multi/sunroofdrain.htm
A weedwacker line works well, don't use compressed air or anything too stiff that could dislodge the line. If that happens, the interior panel has to be removed to reattach it.
