hi all, great forum, i know its not an audi or a tdi but shes part of the vag group so hopefully someone can help me i bought a 2003 fabia 1.4 non runner key symbol flashing, got vagcom and these are the results
Tuesday,19,April,2011,19:56:46:56619
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBNC46Y933832179 Mileage: 56830km/35312miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 FD
Component: MARELLI 4MV 4823
Coding: 00073
Shop #: WSC 00210
VCID: 59BDDBD1E99F
1 Fault Found:
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-10 - - - Intermittent
Readiness: 1110 0101
Address 02: Auto Trans Labels: 001-927-731.lbl
Part No: 001 927 731 R
Component: AG4 Getriebe 001 2996
VCID: 204BB6358A45
No fault code found.
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V30
Coding: 00045
Shop #: WSC 13765
VCID: 418D13B1610F
1 Fault Found:
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
VCID: F2EF0C7D9429
4 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
29-10 - Short to Ground - Intermittent
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q0 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25738
Shop #: WSC 13765
VCID: 3A7F645D0CD9
4 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
28-10 - Short to Plus - Intermittent
00906 - Horn (H1)
00975 - Heated Rear Window (Z1)
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
VCID: 1E3788CDB031
Address 17: Instruments Labels: 6Yx-9xx-xxx-17.lbl
Part No: 6Y2 920 850 G
Component: KOMBIINSTRUMENT VDO V13
Coding: 16441
Shop #: WSC 00050
VCID: 408B16B56A05
TMBNC46Y933832179 SKZ7Z0C1967982
1 Fault Found:
01177 - Engine Control Unit
65-10 - Unauthorized - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 31 GATEWAY CAN 1S33
Coding: 00015
Shop #: WSC 13765
VCID: F0EB06759A25
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 Q
Component: LenkhilfeTRW V250
Coding: 00140
Shop #: WSC 13765
VCID: 3D756F411DF7
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát 0002
Coding: 00067
Shop #: WSC 13765
VCID: 3D756F411DF7
Part No: 6Q2959802A
Component: 31 Tõrsteuer.FS TFK 0004
Part No: 6Q2959801A
Component: 31 Tõrsteuer.BF TFK 0004
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
End ---------------------------------------------------------------------
Address 17: Instruments (6Y2 920 850 G)
20:27:59 Group 022: Immobilizer I
0 Engine Start permitted
1 Engine (ECU) responds
1 Key Status
2 Number of adapted Keys
20:27:59 Group 023: Immobilizer II
1 Variable Code authorized
1 Key Status (Transponder)
1 Fixed Code authorized
6 Immobilizer Status
any help is much appreciated new to vagcom starting to understand it all, but am stuck with this one
Coding: 00073
Shop #: WSC 00210
VCID: 59BDDBD1E99F
1 Fault Found:
VCID: 204BB6358A45
Coding: 00045
Shop #: WSC 13765
VCID: 418D13B1610F
1 Fault Found:
VCID: F2EF0C7D9429
4 Faults Found:
Coding: 25738
Shop #: WSC 13765
VCID: 3A7F645D0CD9
4 Faults Found:
00906 - Horn (H1)
Coding: 12593
Shop #: WSC 13765
VCID: 1E3788CDB031
Coding: 16441
Shop #: WSC 00050
VCID: 408B16B56A05
1 Fault Found:
Coding: 00015
Shop #: WSC 13765
VCID: F0EB06759A25
Coding: 00140
Shop #: WSC 13765
VCID: 3D756F411DF7
Coding: 00067
Shop #: WSC 13765
VCID: 3D756F411DF7
Part No: 6Q2959802A
Part No: 6Q2959801A
3 Faults Found:
1 Key Status
