I have a 2003 Jetta TDI 1.9L with a strong diesel smell coming from exhaust. VCDS shows Fuel timing at green line.
Release Notes
try using Shell V-Power Diesel if You can find it in Your area if not simply switch fuel station. and see if that makes a difference
Hard to gauge smell, they all smell. You might look at injection quantity. If you have a lot of miles, a straight Diesel Purge might help.
what i meant is? depending on where diesel is bought some fuel stations have more sulphure content in it then others giving off more of a sulper smell out the tailpipe.
