I changed my ignition lock and now have this code 00194 Ignition Key Removal Lock - Electrical Fault in Circuit/Open Circuit/Short Circuit to Earth/Implausible Signal.
Anyone knows how to fix this code?
VAG Error Code: 00194
Fault Location:
Possible Cause:
Fuse(s).
Wiring/Connector(s).
Communication Failure with Gear Selector Module.
Selector Lever (E313) faulty.
Tiptronic Switch (F189) in Selector Lever (E313) faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check Communication with Gear Selector Module.
Check Selector Lever (E313).
Check Measuring Value Blocks (MVB) in Transmission Control Module (TCM) (J217).
Check Tiptronic Switch (F189) in Selector Lever (E313).
Special Notes:
Maybe stored in Combination with 28775/U0103/049411.
