I replaced the camshaft and now the starter is barely spinning the engine, where can I find the standard camshaft specs? I think the new one is a couple off thousands to big
Welcome to the forum.
Which model do you have especially the engine code of the data sticker?
Data Sticker/Options Sticker and Engine Codes
Re-check the timing belt settings.
Welcome to the forum Fgus!
You just replaced the camshaft? Did you include, cam bearings, cam followers, cam cap bolts? Without knowing this before hand, it would seem the cam caps could be misaligned, installed backwards or the cam could be 180° out of clock. The hardware on the cam caps is TTY (one time use- Torque To Yield).
You should be able to turn the Engine over by hand, with hand tools. If that’s not possible, you’re going to have to back track check under the timing belt cover and likely remove the valve cover and double check everything. Forcing the engine to turn over could cause valve to piston contact etc.
Hi, did You torque the caps down in sequence? And did You also Oil the cam bearings? Ive just had cams out of X's BMR 2L TDI 125 KW twin cam Pumpe Deuse Passat here in Tasmania, and the torque spec for that is only 20 NM about 14Ftlb so not much torque on bolts. i recall in My miss guided youth nearly 40 years ago tightening up cam bolts on motor bike and didn't take much extra torque to cause extra cam friction.
