My engine (2.0 tdi CJAA/manual tranny 116000 km) used to stutter when driving in 3rd gear at about 60km/h. Owned the car for a year now and noticed it did it only during summer time (above 10 degrees celcius). Also, since I purchased a P3 gauge I was able to associate the stuttering to the exact time where the EGR temp would cycle on and off (goes from 300-400 to 700-800).
Decided to do the anti-shudder valve/EGR solenoid valve and intake manifold cleaning with Easy Off and soapy water (some prefer Superclean to soapy water). Found a fair amount of carbon build up mainly in intake manifold and EGR valve. It absolutely did the job!!!
No more stuttering, EGR transitions are smooth and unnoticed like the car was meant to be.
Most important thing to remember: change all gaskets and intake manifold bolts torque is 8Nm.
This is a new forum layout which is owned by a company last year that doesn't give a dam with loads of bugs which have been reported in the new thread. There is no TDI Wiki at the moment or original similes. It doesn't show the car spec/location.
Here are before and after pictures of parts removed. Not as bad as some ALH soot porn but still....
8550
8551
8552
8553
8554
2006 Jetta (BRM), 5 speed
Wow, that is a HUGE difference! Nice work :) Makes me want to open mine up just to see what's staring back at me
