TO:Moderators- and fellow gear-heads..thanks for allowing me your time...I will probably have to pull the TDI engine from my G-Friends Beetle,-( as it is needs a reinforcing brkt. on the engine) -Or a casting boss- repaired..? I have'nt actually pulled-> inner fender well>?- or any access. to get a def. look- but the main engine support bracket seems to be trashed-..W/ bolts broken out of block ,etc. Is there _only_ two.? that secure the lower "main" bracket to the block.? Does the eng. and trans. drop out of the bottom- easier- ? lol- Or from the top.. Hey- there are no Stupid Quest. -Right..? I also want advice as to the best shop manual, I have read that Bentl.is "not that swell"..OK- Thanks -JB -
