Half way through replacing the timimg belt on my 2004 Bora. It was pretty straight forward upto the point of trying to remove the engine mount. I have managed to get the belt off but cant replace the tensioner or water pump with this in the way. Has anyone come across this before and found a solution.
Many thanks
Rowdy
Yes, Bora=Jetta.
You do have to move the engine around to get it out, if having trouble I would just work around it. Once it's loose, just move it around to get that stuff on.
Discussion Starter · #4 ·
Thanks for the response
I have tried raising and lowering the engine but the mount will not come out. I can probably sort the water pump with the mount in place but cant get the tensioner out.
Thanks
Rowdy
