The smaller (16mm head) bolts holding the (upper) engine mount to the chassis used to be part number N-105-167-01, "stretch" bolts spec'ed for 30 Ft*Lbs plus 90 degrees.
These bolts have been superceded by p/n N-105-167-02, which has threads going all the way up to the head of the bolt (with no so-called "stretch" section / neck)... they're grade 10.9...
What torque spec should one use here??? Seems wrong to continue with the old 30 Ft*Lbs plus a quarter turn...
Yuri
Yuri
