Hi, I was wondering if anybody has experienced symptoms on a tdi-pd engine like temporary engine jerking as it would not get enough fuel accompanied by flashing of dash lights for a few seconds, which go away if one accelerates the engine. A couple of years ago I had a bad electrical contact at the pre-supply diesel pump in the tank. At that time I removed the slide-on contact, pressed it with pliers and reconnected which fixed the problem until recently when i experience the above described failure symptoms. No error codes are recorded by ECU. Any suggestions? Thx.
