1 - 13 of 13 Posts
Window washers, bk wiper, cigarette lighter, heater fan all stopped working in one go have tried all fuses and they are fine anyone any ideas. This has me confused ?‍♀
Looks a bit rusty will open them up in morning and clean prob move it to new hole to be certain and get bk to you thanks first mrk 5 I’ve owned
Electrical fault Golf GTD mrk 5 2008 you need to get your car spec right. The Mk6 Golf GTD came out in 2009, mine is 2010.
I would guess its:
Manufacturer: VW, Date(s) Used: 11/2005-11/2008, Model: Golf GT, Engine Code: BMN, 125Kw, 170PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) GT 16v Timing belt
Manufacturer: VW, Date(s) Used: 04/2009-05/2010, Model: Golf GTD, Engine Code: CBBB, 125Kw, 170PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) 16v GTD Timing belt Timing gears
Discussion Starter #6
  • 8349
    Found this on outer fuse box be told this is what is causing problems will updated tomorrow once I clean all corrosion and white grease all connectors anyone else with this in winter clean up asap
Discussion Starter #10
8352
Now found this inside fuse box think only thing I can do is find decent second hand one or any ideas how to clean this part
1 - 13 of 13 Posts
