1 - 6 of 6 Posts
It depends what is wrong with it.
I did, Engine doesn't start, with ignition on the on position and scanned, no codes appear.
When mine failed, the engine started, but because it failed open, it would not run faster than idle before it missed, belched smoke, and otherwise wouldn't run without stumbling. Codes were thrown for MAF, EGR, and oxygen sensor.
VW Jetta TDI 2006 BRM
did it sound like this?
As I've just posted in your other thread with your knocking problem.
1 - 6 of 6 Posts
