VW Jetta TDI 2006 BRM
So been watching videos and reading posts trying to figure it out. The sound my car is making seems like the cams. The black smoke and no power seems like a bad EGR. Any advice would be great so I know where to start.
A few days ago heading to work I lost all power and engine started knocking pretty loud with plenty of black smoke.
Prior to that she has a leaking EGR cooler that needs to be fixed and when she is cold she stutters and smokes pretty bad till I can clear it out by revving it. My mpg has always stayed at 39-41 mpg 🤷🏻‍♂️
In addition to the above issues I changed the oil, oil filter, and fuel filter 2 days earlier. Only thing to note from that is I did spill some diesel when I did not install the gasket properly on the fuel filter.
I’ll try and get a video up as I’m sure it will help.
That sounds like the camshaft and lifters need replacing.
As I've just posted in your old intro.
Myturbodiesel moving on
Release Notes
Thanks for the info! I added my specs to the signature. Hopefully that helps in the future.
So the cam shaft and lifters would lead to a total loss of power? I guess that makes sense.
Discussion Starter #4
A bit more research has me leaning even more towards the cam shaft and lifters.
Found this YouTube video
Here is what my intake sounds like:
