1 - 13 of 13 Posts
Hi Team,
I'm having an issue with my mk6 GTD for the last week or so, where the car after a certain amount of km traveled goes in to limp mode and drops RPM. Flashing glow plug appears but no MIL light. Wife drives it to work and at end of shift starts the car no problem and doesn't experience any issues after number of hours, and no flashing spiral indicator. Drives home fine with no power loss or any issues.
I have scanned the car last week and today to show this issue. I'm not sure how to interpret this data. EGR valve was the only error last week now it looks like an EGR cooler two.
Two weeks ago car had a flat battery. As potential symptom I though I mention this. Most data on VCDs was in red due to low voltage.
I would appreciate any advice regarding this.
Latest scan posted.
Thanks
Tuesday,24,September,2019,13:46:36:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 19.6.1.0
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ1KZCW064629 License Plate: GTDSILVER
Mileage: 98190km-61012mi Repair Order: Silver3
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCW064629 Mileage: 98190km-61012miles
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BC HW: 03L 907 309 R
Component: R4 2,0L EDC H23 7819
Revision: 42H23--- Serial number: 00000000000000
Coding: 001D0012042500080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
VCID: 6CD7F7908728DC2F55-8039
3 Faults Found:
4875 - Coolant Pump 2
P261A 00 [096] - Open circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 97929 km
Date: 2019.09.20
Time: 16:48:54
Engine speed: 799.50 /min
Normed load value: 22.7 %
Vehicle speed: 0 km/h
Coolant temperature: 77 °C
Intake air temperature: 27 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.020 V
Unlearning counter according OBD: 38
Coolant temperature at radiator outlet: actual value: 65.7 °C
Bypass valve for EGR cooler: status-Bits 0-7: 1
exh.gas recirc.: shut-off conditions-Bits 0-7: 0
exh.gas recirc.: shut-off conditions-Bits 0-7: 7
EGR cooling function: status-Bits 0-7: 0
exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
Temp sensor for EGR after cooler: raw value: -270.6 °C
Exh.gas temp.sen 1: 71.1 °C
4891 - EGR Valve (N18)
P0403 00 [096] - Malfunction
4892 - EGR Valve (N18)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 98136 km
Date: 2019.09.23
Time: 16:24:48
Engine speed: 1788.00 /min
Normed load value: 0.0 %
Vehicle speed: 91 km/h
Coolant temperature: 79 °C
Intake air temperature: 32 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.040 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 258.6 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
EGR Solen.val.: actual value: 34.50 %
EGR valve: offset closed: 1.27 %
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 7
High press EGR actuator: actual unconditioned volt val: 2927.4 mV
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2701
Revision: 05351113 Serial number: 00001107060358
Coding: 0000020
VCID: 56A3B578E1A476FF93-8003
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 163B600D092880FE681106E690220182350800
VCID: 7BF5C4CCFA464B97CC-802F
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001003
Coding: 0000001002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 000FB3209BA0284F99-8055
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 4C180A3A8025F1C0400800C0340001E449510488536D8560648000200040
VCID: 3A7B01C8B5FCB29F97-806F
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 11071 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160711 05 54 0403
Coding: 0230AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H1 9005
1 Fault Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 101
Mileage: 97692 km
Time Indication: 0
Date: 2014.02.08
Time: 00:44:15
Freeze Frame:
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA7ZZGP
Coding: 00003956
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 316926E4608A71C726-8065
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME25256661ZZZQ
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME75242361ZZZO
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H ----
Crash sensor for side airbag: rear: passenger side:
Serial number: 3522QSME540B1D34ZZZX
Coding: 2020200000000000000000
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KGD000X5
Coding: 1892140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E3D5F8C96416FFB3-8023
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Serial number: 0069287
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K6 920 872 A HW: 5K6 920 872 A
Component: KOMBI H03 0607
Coding: 170B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 33652CEC9A9643D754-8067
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 140711F2003599
Coding: 350003
VCID: 356112F49CE25DE77A-8061
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBF1888DDCC21F27-803F
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660458576
Coding: 010000
VCID: 2959CE84405A0907EE-807D
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2106
Coding: 0000692
VCID: 377D18FC46EEAFF768-8063
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 34672FF0579844EF4D-8061
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 326B29E8AD8C4ADF5F-8067
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 052 0208
Revision: 00000001 Serial number: VWZ1Z3L1610091
Coding: 01000400040005
VCID: 2345DCAC2276D357A4-8077
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 356112F45CE25DE77A-8061
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 366315F841E456FF73-8063
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660438729
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 34672FF09F9844EF4D-8061
End-------------------------(Elapsed Time: 03:59)--------------------------
End-------------------------(Elapsed Time: 03:52)--------------------------
So your on another problem now.
VAG Error Code: 16787/001027/4891/4892/7461/7462
EOBD II Error Code: P0403
Fault Location:
Exhaust Gas Recirculation (EGR) Recirculation Valve (N18) - Malfunction
Possible Cause:
Rough Idle Speed and/or Engine stalling.
Loss of Power.
Fuse(s).
Wiring/Connector(s).
Exhaust Gas Recirculation (EGR) Recirculation Valve (N18) stuck/faulty.
Possible Solutions:
Check/Replace Fuse(s).
Check/Replace Exhaust Gas Recirculation (EGR) Recirculation Valve (N18).
When is the code detected?:
An improper voltage signal is sent to Engine Control Module (ECM) through the valve.
I don't have an ID code for Engine Coolant Pump 2.
VAG Error Code: 18062/4875/9867/009754
EOBD II Error Code: P261A
Fault Location:
Engine Coolant Pump 2 - Open Circuit
Possible Cause:
Engine coolant pump.
Engine Control Module (ECM).
Possible Solutions:
VAG Error Code: 01038
Fault Location:
Central Locking Thermal Protection (Central Electronics Control Module (CECM) (J519)) - Intermittent
Possible Cause:
Central Locking not working (partly).
Wiring/Connector(s) from/to Door Locks faulty.
Door Lock(s) stiff.
Possible Solutions:
Check/Replace Wiring/Connector(s) from/to Door Locks.
Check Door Lock(s).
I was on the Ross-Tech forum yesterday, someone posted a question battery drain after using VCDS.
Battery drain after using VCDS?
Battery drain has been a problem for along time its usually the CAN Bus.
What does Ross-Tech forum say about these problems, have you made a new thread?
Hey Keith,
I'm still looking into it. I'm not sure is its the EGR valve or cooler?
Hard to pick. I need to test the valve first. Been quoted $840 for cooler and $430 for EGR valve...... CRAZY
Discussion Starter #4
I have also noticed my thermostat is taking long time to come up to temperature
I'm told by an expert that you only fit OEM EGR valves as others don't work as they should.
Check the part number on.
https://volkswagen.7zap.com/en/rdw/ keep this in your favorites/bookmarks for reference. As it will save me checking ETKA.
Discussion Starter #6
Thanks Keith , I'm familiar with ETKA, and its pain to look for . The website isn't too bad , but you cant search by term.
I have cleaned the EGR throttle valve and manifold. Was completely blacked out. I will no doubt have to replace the cooler. I'm quite annoyed with VW naming terminology.
Even in ETKA the naming terminology isn't convention which is annoying for a Germany company.
Discussion Starter #8
I Know, its very annoying, specially the jump between mk5 and two series of MK6.
Discussion Starter #10
Hey Keith,
I have replaced and EGR Valve ( with cooler) but I'm still getting the same N18 error.
What else should I be looking at here ?
thanks
Discussion Starter #12 (Edited by Moderator)
I have but nothing meaningful.
I have replaced EGR Valve unit, ran the adaptation with UDS protocol and ran the output tests. On all accounts it was successful .
I'm still getting the error. I just scanned the car again and all clean. But after I go for a 5 min drive I get the flashing Spiral icon and car goes in Limp mode. I can turn the car off an recycle ignition and it goes of for a while.
1 - 13 of 13 Posts
