1 - 9 of 9 Posts
Hi guys,
We have 3 TDI(s) which have been relatively trouble free. Right now though, my daughter's 2014 Jetta has given us some issues.
Some background:
Last May, the high pressure fuel pump on her car failed and the dealer replaced it and a bunch of other parts as part of the warranty. I was so glad that it was still covered since it was like an $8K job :eek::).
Then in August, her CEL went on and did an autoscan (see below). Brought it to the same dealer to be checked, their report stated:
Need to remove intake manifold and inspect for excessive carbon build up and
if necessary replace intake manifold. It may be possible that DPF is starting to fail
as well based on mileage, but due to intermittent nature of fault to start with intake
manifold inspection.
Total fee: $1384.87
They informed me that the warranty (extended emission's) has lapsed already.
You would think that with all the work they did with the fuel related issue, they would have inspected (or even cleaned) all that manifold area since they replaced all the injectors, cleaned injector bores, etc.
I declined the service and took the car home.
I then have another independent European car specialist and he said that it's probably the DPF needing replacement. He said that he wasn't equipped to handle that job.
I am still researching this whole thing, but I'm really lost on how to proceed. Don't want to go through the expense of replacing the DPF, or even getting it professionally cleaned which will cost about the same in my area if it is not needed.
In all this time, the car runs perfectly fine.
Any ideas on what route/actions I need to take that make sense, is practical and will require least $$$ output?
Many thanks in advance!!!
Code:
Sunday,01,August,2021,12:02:56:32299
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: 3VWLL7AJ7EM445731   License Plate: JETTA
Mileage: 228850km-142200mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56 75 77
VIN: 3VWLL7AJ7EM445731   Mileage: 228850km-142200miles
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
75-Telematics -- Status: OK 0000
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 M    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H16---    Serial number:
   Coding: 0050078
   Shop #: WSC 84352 939 682342
   VCID: 387F42CF4B2DA04B3B-806C
2 Faults Found:
001025 - EGR System
               P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100001
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 255
                    Mileage: 227628 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 08:00:20
             Freeze Frame:
                    RPM: 2507 /min
                    Speed: 127.0 km/h
                    Voltage: 13.91 V
                    Load: 96.1 %
                    Load: 100.0 %
                    Mass Air / Rev.: 405.0 mg/str
                    Mass Air / Rev.: 415.0 mg/str
008194 - Particulate Trap Bank 1
               P2002 - 007 - Efficiency Below Threshold - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 227931 km
                    Time Indication: 0
                    Date: 2015.12.09
                    Time: 01:48:51
             Freeze Frame:
                    RPM: 2093 /min
                    Speed: 106.0 km/h
                    (no units): 76.5
                    (no units): 40.8
                    (no units): 2.25
                    Pressure: 264 mbar
                    Pressure: 41 mbar
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 9430
   Revision: 05652104    Serial number: 00001404070560
   Coding: 0000020
   Shop #: WSC 44551 111 44551
   VCID: 1427D67F3705A42B77-8040
No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492600FF851202E7921A0042A1100012
   Shop #: WSC 55827 001 1048576
   VCID: 0407E63F876534ABE7-8050
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0334859081
   Coding: 030C0C
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_KESSYPQ35G A02013
   ROD: EV_KESSYPQ35G_A02_VW31.rod
   VCID: 346776FF9F45442B17-8060
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BN    HW: 5C0 820 047 BN
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000002209236
   Shop #: WSC 00066 790 07029
   VCID: 6DD1A39B74EFD5E318-8038
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 5C0 937 087 L    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H34 0425
   Revision: B2034001    Serial number: 08013171140346
   Coding: 7B994B9A08AB0B0008382000240884C50082502E6000000030A050002000
   Shop #: WSC 01151 003 1048576
   VCID: 36634CF78139563B29-8062
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585140527110626
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584140522125418
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH000BRTQK
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0101201 FLE 20140507
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587140520061105
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14102586140523031858
   Coding: 800000
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD04W71R
   Coding: 00004138
   ASAM Dataset: EV_AirbaVW10SMEVW360 001026
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74E7B6FFDFC5042BD7-8020
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Component: BF-Gewichtss.  H10 0046
   Serial number: 6940000Y1400016BHD0K
   Coding: 303036
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H02 ----
   Serial number: 3572MSME3F22717FZZZ2
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H02 ----
   Serial number: 3582MSME41114C44ZZZP
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME5824562CZZZX
   Passenger side rear thorax airbag crash sensor:
   Subsystem 5 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME32292F2DZZZ
   Crash sensor for front airbag: driver side:
   Subsystem 6 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Fahr  H02 ----
   Serial number: 3556LSME71554A2DZZZ+
   Crash sensor for front airbag: front passenger side:
   Subsystem 7 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Beif  H02 ----
   Serial number: 3566LSME5962632DZZZ+
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5C6 920 953 A    HW: 5C6 920 953 A
   Component: KOMBI         H04 0809
   Serial number: 00000000000000
   Coding: 270A01
   Shop #: WSC 00066 790 00123
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2B556D83427B1BD346-807E
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H34 0425
   Revision: B2034001
   Coding: 102200
   VCID: 70EFBAEFA3DD380B33-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0809
   Serial number:
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADBA8878D01C2DB7D-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000113047003
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306F7AEF6B5D780B73-8064
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 P    HW: 1K0 035 274 P
   Component: RNS315-NAR    H80 0500
   Serial number: VWZAZ2P0275564
   Coding: 040900610100060000008000
   ASAM Dataset: EV_RNS315NARV2UDS 001705
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 31697FEB605771037C-8064
   Data carrier:
   Subsystem 1 - Part No: 3AA 919 866 B
   Component: NAR_V6N  0051
1 Fault Found:
1048669 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 224540 km
                    Date: 2021.05.25
                    Time: 11:13:49
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 397947CB7027B943C4-806C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H08 6815
   Revision: --------    Serial number: EAA098A0151617
   ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
   ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 26439CB7599926BB99-8072
Address 75: Telematics (J949)       Labels:| 12E-035-284.clb
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140521
   Coding: 02630102C2423A007F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 001010
   ROD: EV_OCULow_001.rod
   VCID: 53A515633A8B63132E-8006
1 Fault Found:
2103041 - Control Module
          B1788 F0 [009] - Start Prohibition Deactivated
             Freeze Frame:
                    Fault Priority: 8
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 228853 km
                    Date: 2021.08.01
                    Time: 12:01:41
Address 77: Telephone (J412)       Labels:| 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666153018
   Coding: 0A100300A0010110
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI.rod
   VCID: 2E53649771696EFB61-807A
End-------------------------(Elapsed Time: 03:30)--------------------------
How is the car driven? That will determine how likely there's intake clogging. I would NOT expect the dealer to clean/replace an intake manifold as a normal part of a procedure to repair HPP failure. In general it's quite a messy job: have no experience with newer engines, but doubt that it's much different than the older ones (such as ALH engines, which I've done plenty of).
Not familiar with these engines/systems, but have an idea on CR engines with DPFs. I'd look around for a good truck shop and see if they could clean the DPF. DPFs CAN be cleaned, at least once I believe.
My daughter primarily drives it to and from work (around 70 miles total) about 4 days a week.
As far as cleaning the DPF, there's a company that does it for $450, but they don't perform the take out and re-install of the DPF. There's a mechanic who would the labor of taking it out and re-install for $600. I asked around some dealers for a NEW DPF and it'll be around $1300.
So my dilemma is do I go that route right away or go have the EGR valve replaced ($170) plus install costs. In my mind I'm thinking, it is a process of elimination and the EGR route is quicker and cheaper to do first.
What do you think?
Hi guys,
Some background:
Total fee: $1384.87
Code:
www.Ross-Tech.com
   Coding: 0050078
2 Faults Found:
001025 - EGR System
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 255
                    Mileage: 227628 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 08:00:20
             Freeze Frame:
                    RPM: 2507 /min
                    Speed: 127.0 km/h
                    Voltage: 13.91 V
                    Load: 96.1 %
                    Load: 100.0 %
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 227931 km
                    Time Indication: 0
                    Date: 2015.12.09
                    Time: 01:48:51
             Freeze Frame:
                    RPM: 2093 /min
                    Speed: 106.0 km/h
                    (no units): 76.5
                    (no units): 40.8
                    (no units): 2.25
                    Pressure: 264 mbar
                    Pressure: 41 mbar
   Coding: 0000020
   Revision: 00H46001
   Coding: 030C0C
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   Coding: 303036
   Coding: 270A01
   Revision: B2034001
   Coding: 102200
   Serial number:
   Coding: 000007
Cannot be reached
   Data carrier:
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 224540 km
                    Date: 2021.05.25
                    Time: 11:13:49
   Revision: 00H22000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 8
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 228853 km
                    Date: 2021.08.01
                    Time: 12:01:41
   ROD: EV_UHVUMI.rod
Hi guys,
Some background:
Total fee: $1384.87
Code:
www.Ross-Tech.com
   Coding: 0050078
2 Faults Found:
001025 - EGR System
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 18
                    Reset counter: 255
                    Mileage: 227628 km
                    Time Indication: 0
                    Date: 2015.12.07
                    Time: 08:00:20
             Freeze Frame:
                    RPM: 2507 /min
                    Speed: 127.0 km/h
                    Voltage: 13.91 V
                    Load: 96.1 %
                    Load: 100.0 %
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 227931 km
                    Time Indication: 0
                    Date: 2015.12.09
                    Time: 01:48:51
             Freeze Frame:
                    RPM: 2093 /min
                    Speed: 106.0 km/h
                    (no units): 76.5
                    (no units): 40.8
                    (no units): 2.25
                    Pressure: 264 mbar
                    Pressure: 41 mbar
   Coding: 0000020
   Revision: 00H46001
   Coding: 030C0C
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   Coding: 303036
   Coding: 270A01
   Revision: B2034001
   Coding: 102200
   Serial number:
   Coding: 000007
Cannot be reached
   Data carrier:
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 224540 km
                    Date: 2021.05.25
                    Time: 11:13:49
   Revision: 00H22000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 8
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 228853 km
                    Date: 2021.08.01
                    Time: 12:01:41
   ROD: EV_UHVUMI.rod
So if you’re not privy to the fact. If your DPF filter is bad or on the way out, outside of all the trouble codes you may have. Take a quick peek at tail pipe if there is “any”soot and I mean “any”DPF is bad, it should look brand new. Believe it or not…so if under warranty you will have to make VW replace. That in itself is an endeavor.
I have seen codes P0401 and P2002 twice on my 2012 Golf Mk6 TDI .in both instances there was soot on my exhaust pipe and my dealer replaced the DPF. Now being out of warranty I use a Polar FIS module to monitor regen status on the dashboard screen and keep driving the car until regen is over.
Well there is an alternative, unless you’re in a state that requires diesel inspections. Replace with a RawTek exhaust and install a Malone stage 2 tune, if you have DSG automatic you will have to reprogram. If not you’re good to go. No DSG tune 6speed manual…about the same cost as a new DPF. Plus cost of install, unless you can do the work. Be aware of forcing a regen after certain soot levels. VW states it’s possible to burn the car down
Discussion Starter · #7 ·
For me, this alternative is not possible being in CA. :cautious:
Discussion Starter · #8 ·
Ok, thanks for this tip. Will definitely check it now.
Based on your mileage of around 144k miles, your DPF is past due for replacement or alternatively cleaning. Also, if you (or the previous owner) are not using the VW spec 504/507 oil you will have issues with the DPF.
1 - 9 of 9 Posts
