My question to you guys is that got a 2010 volkswagen golf . I replaced the ECU with a used one same part number when I installed it turns on, and the car shuts off seconds after it turns over and the immobiliser is Active ... What's the cheapest way to go so I can drive my car???? Please help
Welcome to the forum.
Ecu's aren't plug and play even if the part number is the same. Each one has to be set to the immobilizer and read coil on the ignition switch.
Later VAG models this can only be done at a dealer who has online access to the database.
As that link shows there could be an error code.
