Anyone know why the Immobilizer is flashing. Currently getting a bunch of codes and a no start condition. I was diagnosing a turbo waste gate issue and the car shut itself off while driving. I have charged the battery and come up with this scan. Also, I changed the Relay 109 and still came up with this same scan.
Friday,05,November,2021,11:12:20:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.0.1 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 3VWSP69M62M008291 License Plate:
Mileage: 414140km-257334mi Repair Order:
Chassis Type: 9M (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 3VWSP69M62M008291 Mileage: 414140km-257334miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FD
Component: 1,9l R4 EDC G100AG 4102
Coding: 00001
Shop #: WSC 00066
VCID: 57BD3E5BB50D6D3E13-4B18
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 KT
Component: AG4 Getriebe 01M 4891
Coding: 00000
Shop #: WSC 00000
VCID: 0C1711373C4B5EE66E-0962
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 2A5BB7AF86FF20D67C-515A
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A7B87EF265F90560C-513C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 M
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 00222
VCID: 326BAFCFFE2F6816C4-515A
3VWSP69M62M008291 VWZ7Z0A3805139
3 Faults Found:
01176 - Key
65-10 - Unauthorized - Intermittent
01179 - Incorrect Key Programming
35-00 - -
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70EF65C730A31A06F2-513C
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 377D9EDB154D8D3EF3-4B18
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0002
11 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module; Driver Side (J386)
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-10 - - - Intermittent
01332 - Door Control Module; Passenger Side (J387)
00933 - Electric Window Motor; Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
End-------------------------(Elapsed Time: 05:03)--------------------------
Most likely an earth fault. I had similar after blocked sunroof drains. Wet carpet. Corrosion on earth lug at base of pillar in footwell. Find the earth lug and clean it and cut back the carpet underlay so that it doesn‘t draw water onto the earth stud. Convenience computer needs a good earth.
