1 - 6 of 6 Posts
If you lay on your back looking under the car,it should be on a hose on the bottom left.
Discussion Starter #5
Just pulled the hose
But if it is a plug and someone has a pic I would still like to know. Thanks Now on to the fun stuff
If you cannot find a knob/valve on the hose then I would suggest simply removing the lower hose from the radiator and let it drain into a oil change drain pan or a homemade container. Replace hose and refill.
1 - 6 of 6 Posts
