took this picture of my door handle.
when the dealership did the ignition switch recall, they didn't replace the door locks ...
of note is the microswitch which can cause problems with the alarm system. note that the microswitch can't cause problems with the vacuum pump for the door locks - only a vacuum leak or vacuum pump problem will cause it to run constantly
pic is pretty much life sized
