1 - 7 of 7 Posts
Hello everybody just joing your forum!! What a wealth of information!! I'm a new owner of a 1997 Passat Tdi...helped out a buddy with some financial issues, so I know very little about this car. The auto door locks seem the work okay except for the rear driver side door, which is locked. I doesn't open fom the inside or outside. The door plunger does rise and lower as expected but no unlocky!! I tool this to the dealer and they quited me $400 to open and then repair the door latch. My question is how can I open the door (without damage)?
Look through this writeup to remove the door cards.
http://myturbodiesel.com/1000q_how_to/a3b4/passat_dcard.htm
There could also be an issue with the handle. http://myturbodiesel.com/1000q_how_to/a3b4/doorhandlefaq.htm
$400 is way too expensive. For all you know, something fell off.
Study those writeups for pictures. Then remove the black plastic cover and the latch pictured here.
you can see how the plunger locks and unlocks the door once the panel and latch are removed.
If the plunger moves ok then you also know it's not a vacuum line problem. There is a vacuum pump in the trunk and vacuum lines in the door that move the plunger up and down smoothly instead of clunking it up and down with a solenoid.
Locked Door
Thanks, these are great...unfortunately I can't open the door. To remove the handle I need to access the screw on the inside of the door, which is not possible with a closed door. Can I reach the latch from the inside of the car somehow and manually release the door?
1 - 7 of 7 Posts
