Ok when I first had my Golf the DRLs were on all the time which I hate.
I went back to the dealer to next day over a scuff on the bodywork and I asked can the DRLs be turned off at the same time. They took it in the workshop and fixed the scuff and fixed the DRLs at the same time. I asked them how they turned the DRLs off and they said something with the indicator switch and ignition switch sequence which sounds like disable/enable without VAGCOM. THis proceedure doesn't work on my standard HID lights.
I changed the tap flasher today now the DRLs are back on and I can't get them off. This Long Coding needs to be explained in more detail as the Ross-Tech help is ****.
How to disable the daytime running lights or use foglights as DRL on your mk5 VW Jetta, Golf, or Rabbit (2005-2009)
