Noticing a slow decline from
39-40mpg to 35-36mpg on my 2014 tdi sport wagon. Also noticed that the trip computer always calculates 2-3mpg higher than if I do the math based on fill up gallons and miles on the trip.
Anyone have any suggestions? The dealer replaced rear calipers and I replaced front calipers recently and I was hoping that would help but hasn’t made a difference. Decline has been over the last year or so.
fuel and air filters are within the last year.
Missing my old alh that got 45+mpg…
Winter fuel always decreases MPGs
I see that you’re in the Vermont are you letting the car warm up for a while before you start driving ? That’s hurts MPGs as well
Any change in driving habits? I will typically drive extreme grandpa mode until the car warms up. How may miles do you have on it? I had an extreme mpg drop before I had to replace the cam on my 2005 Passat. RPMs were too high and would take too long to get to highway speeds which killed the mpg
My mpg dropped significantly when my thermostat went bad. I could see the running temperature was down a little with the OEM gauge, so you'd probably know if you had that same issue.
