1 - 10 of 10 Posts
Hi all, was able to change timing belt for my 2006 TDI Beetle with the excellent info from this site. Need to change CV axles. Are there any tips, torque specs and procedures that can be shared? RonC_808
Are you wanting to change them out as an assembly? That is the easiest and I would recommend contacting raxles.com (No I'm not an employee) as their axles are outstanding and they will ensure you get the correct ones along with all new hardware and installation instructions. You will never have to replace them again if you put raxles on
Discussion Starter #4
Thanks Dave N. for your input. Yes, I was planning to change the left and right CV axle assemblies. Did contact RAXLES and actually got a quote to have CV axles shipped to Hawaii, the response from RAXLES was "Holy cow!". Yup, shipping to Hawaii is expensive. May need to settle on getting axles from a local auto parts store. Mainly need the specs/procedures for the axle nut(s) and the torque specs for the axle inner bolts.
Oh thats easy but I would need a photo of whats in there because there are three different types in use on the MK4 and they are all a little different
Discussion Starter #6
Hey Dave N.
Took some pictures, LMK if you need better ones. Shots are behind the brakes and tried to take a picture of the portion that connects to the transmission. BTW the engine code is BEW and the transmission,DSG.
RonC_808
8521
8523
Hey Dave N.
RonC_808
View attachment 8521 View attachment 8523
Those are AAR-3300i axles. The transmission side bolts are torque to yield and need to be replaced whenever removed and their initial torque is 7.5 foot pounds then 52 foot pounds and check them again after a hundred miles. The nut on the outside of the axle is likely a 12 point and also needs to be replaced whenever removed. Assuming the replacement is a 12 point the torque is (with the weight of the car on the ground) 148 foot pounds, then back off 1/2 turn, then roll the car one half turn on the wheels, tighten to 37 foot pounds, plus 1/6 turn. Not too many manufacturers use the 6 sided nut on these anymore but if you get one of those let me know and I will tell you the torque on them
Also you want to be sure and have the right triple square driver bit for the bolts that go to the transmission side. They aren't torx or allen bolts
Discussion Starter #10
Thanks for the information Dave...
Aloha
RonC_808
1 - 10 of 10 Posts
